71GTX440
Was yours running "hot" for awhile?I actually own a BluePrint 408 stroker engine, so I can speak from experience.....unlike others who are discussing builds by others.
I am running the Chrysler radiator fluid recommended by blueprint engine. No 50/50 mixtureWith a 50/50 mix of glycol and a 16 lb cap, that's not that hot. I've mentioned the virtues of a thermostat with a larger opening, like the EMP/Stewart from Summit. Flow through an 1 7/16" opening is tremeandously better that the 1 1/8" opening on a Stant.
Yes....but it calmed down.Was yours running "hot" for awhile?
What temps was your engine getting up to? I am not driving aggressive or racing, just typical cruising aroundI actually own a BluePrint 408 stroker engine, so I can speak from experience.....unlike others who are discussing builds by others.
I got it up to 202F in medium density traffic......during a parade a couple of years ago it hit 212F ....but on the open road I runa round 178-183FWhat temps was your engine getting up to? I am not driving aggressive or racing, just typical cruising around
Verified the thermostat opens as it should and observed coolant flow within radiator. I have a 16" puller fan, the highest 12" fan I found pulled a little over 2000 cfm. There is a dual 12" fan setup that will pull a mid-4000 cfm with shroud.My opinion is that you don't have a problem. If it hit 212* or so with the outside temperature +-100* you are still about 50* from boiling over! As was said, new engines always run hotter until they're broken in. Sure, double check that the thermostat opens on point, that the timing is correct and the plugs look good. Take it out in the evening or morning when it's cooler and see if the car runs cooler, like it first did. Also, you really have to watch the ratings on fan CFMs. The highest ACTUAL rating I could find was a Summit dual 12" set-up with shroud for my 26" Griffin radiator and it is 2600cfm. I tried many mechanical fans (even the 7 blade Mopar 18") and the Summit ones cool my 446" the best. Again, try not to throw a bunch of money at a perceived problem. Keep driving it...
