First, I'm not from Boeing. The problem can be traced to NOT trying to duplicate what MOPAR engineered. The GLENN RADIATOR is expensive....so everyone or slmost everyone goes to aftermarket aluminum designs to save $$$, but spend the same smount of $$$ or more fiddly ******* around trying to achieve the same results. Radiators or heat exchangers are designed to transfer BTU/Hr (heat) generated in the engine to the air via the circulated coolant.......regardless of the advertising saying: "this radiator will cool *** HP"...except its not a hp function but the WASTE HEAT or excess heat generated by the engine and not propelling the car. 500 hp engine will not produce 500 hp worth of waste heat. For example....
1HP ≡ 9,500 BTU/hour) so, 9,500 btu/hr x 500 hp = 4,750,000 btu/hr heat load which in reality does not occur. Only the waste heat or unused heat is exchanged. But everybody just accepts the hp number as gospel. Likely only 10-15% of the total published hp will be required to be transferred as waste heat. Air conditioning adds additional heat load (latent heat) to the radiator's cooling air, making it less effective or a bigger radiator is needed. As noted b4 thermodynamics is an exact science but one must know numbers to accurately design the cooling system.....the shotgun approach does not work......
BOB RENTON
