ChargerST
I need to order custom pistons and need to provide the depth for the valve pockets. I know this is not a straight forward calculations as P/V clearance is not measured at TDC and full lift. My idea was to provide a general depth figure which would be on the safe side to allow a cam change later. I think that 440 source pistons for example allow cams up to .680" lift.
Which is a somehow valve pocket depth figure?
btw I use Trick Flow 240 heads - is the valve to deck distance the same as on production heads (e.g. 906s)?
