westie47
I bought a new dash harness and found out that they are just a basic harness and didn’t include wiring for any extra options like headlight buzzer, light delay etc.
I’ve gone through the wiring diagram and have chased down most of it but I am stumped by these:
The red wire is for the cigarette lighter however the lighter itself has two spade connectors on it. Is there a short wire from the lighter to the harness that I’m missing? There’s no place for the power wire to plug in to.
According to the wiring diagram, these two ends go to the left/right door switches but it’s not long enough. It’s quite a bit of messy wiring, how’s from map light, timer delay, etc.
should I just run a wire from each door switch to here?
Last is the wiper switch and washer fluid connectors. The wiper switch is obvious but the wiring diagram shows one brown wire from the washer fluid to wiper switch and the other brown wire to the bulkhead.
My harness has two pairs of brown wires with the same connectors. Can’t figure out which ones go where.
Any advice is appreciated.
