by the battery fitting the application he's talking about the electrical app not if the battery fits in the tray. if you put a heavy duty high amp battery in, the stock system cant handle it and you get the ammeter, bulkhead, over load problem.re-charging the extra amps of the heavy duty battery is the same thing as over loading the STOCK alternators charging capacity to run lights, radios, extra fans etc. any extra high drain load on the stock system needs the re-wire by pass.
Yes but that's EXACTLY why I say he is incorrect if he's alleging this was a "good design." Even in the 60's and 70's you could get some pretty darn decent batteries in group 24/ 27, long before Optima and other specialty batteries came along. A properly designed charging system should be able to cope just fine. Frankly, this IS where Ford/ GM has Mopar beat all to hell.
Not only that, the "heavy" of the battery really doesn't matter. Let's say you have a factory stock (I did) 383 or 440-6 Roadrunner. Let's say you leave the lights on a little, and either jumper it, or maybe it will start on it's own. You have a battery big enough to crank a 440-6 -- just like the car was "designed" and with a low battery, that factory 35-45A alternator is going to be charging like hell.
I've seen LOTS of these fail or become pretty damaged, and I'm not even a "pro" mechanic. These were over the years, friends and relatives, acquaintance, and others such as members of the 4x4 club we used to have.
Let's take an example. You have a factory car, in an area that has both a need for A/C in the summer and heat in the winter, and an owner who does a lot of city and night driving. This means that there are times, stopped or slow, when the battery is supplying considerable power while discharging. As soon as you speed back up, with lights/ heater or AC running, now you have to recharge. So there is a constant cycle of charge / discharge through the bulkhead.
Even Mopar went with shunt type ammeters in the big cars somewhere around 72. Why they kept the old ammeters in pickups and vans is beyond me.
Here's the bottom line. Bulkhead connectors are basically just push-on spade connectors. These were NEVER designed to handle 40 - some - odd amps, much less more
I used to service HVAC/R, and many of the heat pumps around here have nothing more than what amounts to a forced air electric furnace, which provides the blower as well as emergency heat. I used to carry LOTS of replacements and high temp wire in the truck, because if you service an electric furnace, generally you'll find some failed/ failing spade connectors. THOSE only have to carry about 20A, as the usual electric heater element is 5KW (20A x 240V)
