DetSon
"calm disposition" hahahah. That generally lasts for about an hour.
Ignition switch was one of the first things I switched. I still can't figure out why it didn't work before I did the amp bypass but it did after. I need to recheck if the power switches to the yellow wire now that I have it cranking. I will have time later to figure it all out.
Where I'm at now:
Everything is new from battery cable's to and through bulkhead and to starter/starter relay. Correctly executed amp bypass. MSD 6AL box to new coil to new pickup/reluctor. I get one spark at the #1 plug then nothing else.
In the new distributor I've noticed a definite difference in quality of the parts and fitment inside. I'm really hopeful it was a bad pickup/pickup fitment or just something with the cap/rotor in general. It was hard to diagnose the distributor with nothing to gauge it next too. I have to check but I think the rotor I have isn't correct.
24 hours and hopefully my hairs blowing in the wind.
Where I'm at now:
