Meangene83
1973 plymouth roadrunner, 400 cid, 727 auto, edelbrock 4 brl carb.
So I have a fuel tank that is full of crud. Upon filling up the tank and peering in the filler neck, I could see all kinds of crap floating around in the tank.
This explained why the car had been idling rough and giving me fuel related problems.
The tank was "new" and installed by Previous Owner. Problem is PO was a hack, and most likely did not replace the Sender, sock etc...
So I have on the way (classic industries), a new tank, sender unit, sending unit filter sock, new locking ring and seal and a new fuel pump.
Here is the problem...
I am trying not to replace the fuel lines. What can I expect in the way of crud being in the fuel lines and how should I go about cleaning them?
It was recommended to me to , get some carb cleaner and spray it into the fuel line, then blow compressed air thru the line, while at the other end of the fuel line there is a bucket with some rags to catch any crud. They said to keep repeating this till the bucket at the other end comes out clean.
Sounds like a good plan but I was hoping to hear any other tricks and other TIPS relating to a major fuel system changeover.
A side note, the fuel vapor separtor manifold above the fuel tank? What should I do with this?
Thank you for sharing any wisdom. I will probably tackle this in the coming week.
Gene
HERE IS MY CLASSIC INDUSTRIES ORDER.
Gene
K404 | FUEL SNDNG UNT FLTR STL 5/16" | UPS | 1 | $11.99 ea | $11.99 | |
MF292 | 62-76 FUEL LOCK RING & GASKET | UPS | 1 | $7.99 ea | $7.99 | |
MF438 | 71-73 B-BODY SNDG UNT-3/8" | UPS | 1 | $69.99 ea | $69.99 | |
M6935 | 73-74 MOPAR V8 400BB FUEL PUMP | UPS | 1 | $25.99 ea | $25.99 | |
FT6014B | 72-73 MPR B-BDY FUEL TANK-NTRN | Oversize-2 | 1 | $199.99 ea | $199.99 |
