petieg383
Here's what I got guys. 70 Roadrunner, 440 4 speed. Pretty stock engine. 26" radiator, 190 stat, mechanical fan with 6 blades, Mopar water pump. Runs right at 190 when going down the road as expected. As soon as I stop it heats up and will keep going an going up. I start moving it cools back down again. I'm thinking the fan setup ain't so hot. Pun intended. I do think the radiator and water pump are good however since it does cool back down when moving.
I've bought the recommended 180 Stant thermostat and the Hayden 2675 clutch fan that's I've seen in the sticky's about this topic. I'll also replace the bottom hose, as it seems squishy but I don't 'think' it's being sucked closed when revving a little higher. Besides this thing heats up at idle at a stop, not when rollin.
The question I have is about the fan shroud. Does this look right? It's really biased to the passenger side. Also the fan is sticking almost out of the shroud, and is over 2.5" from the back of the radiator. These things can't be helping my situation. I'm hoping the new clutch fan will bring it closer to the back of the radiator.
A little help from the experts here please. And pics if you can provide them what it's 'supposed' to look like when it's a stock setup would be great. I can't find anything on the net at this point for a reference.
