71_Duster
I have some major driveability concerns with the Edelbrock AVS 800cfm on my 440.
First up the idle mixture screws seem to do nothing. Newer carb blew them out etc no change. I'm thinking to get a decent idle speed that the transfer slot may be exposed causeing it to pull fuel from there?
Also off the line stomping the pedal will usually cause an instant stall.
While cruiseing 3/4 to full throttle too quick will cause a major stumble/hesitiation and what sounds like a pop or backfire through the intake.
Float levels are checked and set, fuel pressure is regulated to 5.5psi, inside the carb is nice and clean, jets and rods are stock calibration numbers, pump cam arm is on the lowest hole -I tried mid and it didnt even want to rev decently in park-
Vacuum advance is on the ported side. All in timing is 34deg mech.
I'd read that some people find drilling a small hole in the throttle plate solves many issues by beign able to turn the idle speed screw out and covering the transfer slots. Is this my case?
Cam specs:
1973 Chrysler Newport 440 4 BBL cleaned & deburred.
.030” over, crank
.010 under mains & rods, ARP head & rod
bolts & windage tray pistons- .030
H143 CP hyperutetic & file fit rings R927835
performer RPM HEADS & intake, 800 CFM Edelbrock Thunder Carb,
Hughes-timing set, CAM, lifters, rocker shafts, roller rockers,
Hughes CAM-HEH 2832BL
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .524"
.540"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .558"
.576"
Intake Duration at .050"
Exhaust Duration at .050" 228°
232°
Lobe Separation Angle 110º
Intake Opening at .050"
Exhaust Opening at .050" 7° BTC
49° BBC
Intake Closing at .050"
Exhaust Closing at .050" 41° ABC
3° ATC
Min. Suggested Cylinder PSI 165
TTI 1 7/8” headers 2 1/2” pipes with X pipe.
Cam specs:
.030” over, crank
.540"
.576"
232°
49° BBC
3° ATC
