I hope the OP got his brakes done by now, its been over a year![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
4 wheel drum brakes here, no problem stopping plus we rarely get rain in the southwest. I agree with rebuilding enless they are too badly pitted, as one of mine was. Not impressed with the Dorman cylinders, long and skinny bleed valve looks fragile and the one I used needed to be super tight or else it dribbled fluid. Plus the rubber boots are not as good as original (if they are still good.)
Another thing I learned was to consult the service manual because whoever did the brakes last may not have done them correctly. On mine both sides were sprung wrong, had 2 yellow long springs on primary and secondary shoes. One is suppose to be fatter and shorter. Live and learn.
Always replace the rubber hoses as well because they will swell with age and act like a one way valve holding the cylinders out against the shoes. Cheap protection and will save headaches later.
