Another thing to add to the fuel disscussion is the changes to the fuel with regards to ambient temperatures. Gas is modified for cold to hot temps. If you picked up fuel at the local station when the temps have been cold and suddenly it gets hot, like out here on the left coast, this can cause the fuel to boil. When I worked at a speedshop back in the early 80's we sold alot of carb heat shields made by GM for Vette applications that worked extremely well. They were just a gasket, heat shield, gasket arrangment that didn't have vacume leak issues like the multiple plate/gasket ones that get over like 1/2" in stackup. GM of course discontinued them but you might be able to get them from a resto supplier. They were made in standard flange and spreadbore styles so you should be covered for either direction. They also had the firing order stamped in them which is the same for us. I used them on my Duster and Challenger and said goodbye to the fuel boiling. I'm curious to see how they would work with the newer fuels that have been spiked with alchohol or the E85 that some use.
