- 11:51 AM
- Feb 29, 2020
- Heart of Dixie.....
Guys, Edlebrock 1406 carb was regaskited/cleaned and installed less than a year ago. Fired up and fine tuned, it ran very well. Car sits for almost a year not cranked. Now gas floods out the top on both sides of front two barrels. Okay, I'm thinking floats stuck open. I pull the carb, turn it upside down and shake all the gas out, hoping to unstick needle and seat. Carb turned right side up with air pressure put on fuel inlet and has air flow, as would fuel flowing into an empty bowl. Turn carb upside down, which should close fuel inlet needle and seat, and it does. Cannot move any air through inlet, which proves to me float needles are seating. Reinstalled carb and still having fuel flow out the top. What else should I look for in taking the carb apart. I just can't believe the float levels are off. that much from only sitting a while. thanks
