You have a fuse link. When you overload that the whole system is most likely dead. There are some variants depending on year. You take a older car and load off the alternator stud you are asking for problems. Worse when the alternator dies and all loads are on that old wiring. Failures will be in wires overheating, ammeter looking like a toaster element along with the bulkhead connections. If you have a bypass done and have a large 6 gauge wire or bigger to the alternator it will help. Just look at what has been done to cars for the last 25 plus years. They run a PDC with all loads including alternators of of fuses. Go out there and find cars, trucks, equipment that run off the alternator stud. Good luck with that search. If that was the way to do it the factories would have done it. Like I said no one will do a hack job like that on anything I own.
I don't care what cars today have. Does our 60s car have the same electronics as a 2019 dodge pick up? NO so don't compare .
So as you stated the only fuse , is the fuseable link on the engine side of bulkhead.
You fry your fuseable link, the system is not dead, until you turn off your car. Your ALTERNATOR will keep the car running. Your alternator DIES, yup your car will go threw a slow painful death as the batttery supplies until its drained, it won't cook everything. Remember that fuseable link???? Load becomes to much , guess who pops?
So with running everything off the battery post, Your power is coming from the "battery" But your battery is simply stored energy, so it only last so long. You NEED the alternator to keep that battery charged. In the FACTORY setup , ALL that current, is now going ALL the way threw the car threw that bulkhead ( which is a known WEAK link ) and trying keep that battery topped up. You now put that LOAD on the alternator side , the LOAD no longer has to pass threw every connection to make it back to the battery. It is fed right off the alternator to the load. Lets not forget of course this NEW load has an inline fuse.
You run a bunch of junk off your battery, its not going to regenerate by itself. It needs the alternator. Your line of thinking is to have the battery constantly be in a state of discharge, and have the alternator keep it up. Which means constantly sending current threw every weak link in the system?
THE FACTORY system is not perfect, its actually horrible. The split point is honestly the famous AMP gauge. Its crude and rude, but honestly it tell you the entire story of the electrical system, IF you undersand it.
You do you. Will your way work, yes it will. Will my way work , yes it will. The important thing to know is how THIS system works.
Ohhhh and can you show me where the ABS, BCM, ECM, Blind spot detection , DC to AC inverter, adapative cruise control, DRL and air bags are??? I can't find them I.m just a hack,
