What alternator did you get that was 80 amps? What alternator options do I have OTHER THAN what the part stores say will fit.
First, I'd strongly suggest one of the RT Engineering units. I went through my panel, with a spare, choosing the parts I wanted to use. But...I screwed up! I had the old voltage reducers, but decided to get a new one. It only lasted a week, before going out, and cooked my fuel/temp gauge. So, yeah, had to have the gauge rebuilt, and got the RTE reducer unit. All good to go, now.
Alternator? Not that it matters, but my 64 sports a 69 440. Only saying, I had parts and pieces laying around, that I could choose from. I picked the best alternator I had, and had it tested and rebuilt. That's when I was told it was an 80 amp...was hoping for a 60 amp. After research, and being told it wouldn't hurt, it got slapped on. I'll note here though, especially since I was adding more amps, I added parallel wiring to the alternator. Yeah, that's something you can look up. Adding that wire, that went straight through the firewall, with the 'stock' wires going through the block, split the amp load. And, it's hooked up to the stock ammeter, too. Works great!
Though...a big but here! 45 amp, or 80 amp, still the same deal. MUST have good wiring/connections, and the other devices in that charging system. Okay.
I went through every inch of wires, in the entire car. Most of the electrical components should/need to be checked. If any wire had more than 0.5 ohms reading, it was replaced. So on, and on. If the wiring isn't good enough, it only makes problems.
IF the wires are good, corroded connectors can be cleaned with...lemon juice. I used a container, that the ends of the harness could fit it. Let it soak for a day, rinse with water, and their clean.
Is it all a job, yeah.
