Moparnocar
I idle at 650 ish, I wouldn't go any higher than 800, it's gonna wanna creep, little harder on trans etcWell, my alternator seems to check out. He tested all the diodes and then put it on another machine to test it. It passed the tests fine. He put in some new brushes anyway becuase mine were a little worn. He did this all in front of me. He put it back on his tester after this and said it was better with the new brushes. He didnt charge me for any of this. I will put it back on the car tmrw and see if the new brushes changed anything.
Assuming it does NOT change I will try turning the idle up even further. I think it's at about 800 when I'm in DRIVE with foot on brake. It rises to about 1000 when I shift into PARK or NEUTRAL.
What RPM should my idle be at in everyone's experience?
What's the highest idle speed I should go to? If i go high enough it will solve the problem I'm sure ... but then again I dont want a ridiculously fast idle. I have a timing light to test RPM.
How fast should the car move forward if I take my foot off the brake. Right now it quickly starts to move 2-3 mph if I take foot of brake. Feels on the faster side of "normal" to me already.
Even if that does help, I will likely have to address the 0.9v voltage drop. I'm thinking I will need to trace the power from battery to alternator and then address any bad connections. Hopefully it's all somewhat accessible and that it's only a bad connection and not a bad length of wire.
I also have one of those new electronic voltage regulators coming in the mail which I'm hoping will help.
Any thoughts ?
Have you drop tested from the starter solenoid to bulkhead? Do the outside then inside to compare . Also test wires to regulator, and fuseable links
