Moparnocar
Voltage drop is a better test, you are correct. Ohms test works in MOST test, however, if you have multi strand wire, it can pass ohms but not handle currentOk I identified another voltage drop that isn
New ignition switch did not fix it. A voltage drop test is a very similar test to a resistance test. Bas9ically instead of measuring resistance when the wire has no current passing through it. You measure the difference in voltage between two points on the same side of a circuit while the system is under load (such as car running or a switch on.)The reason I was told to so a voltage drop instead of a ohms test is that supposedly wiring can sometimes pass an ohms test but then fail a voltage drop test. So a voltage drop test is actually better at showing you if voltage is getting "stuck" anywhere in the wiring or electrical system.
I'm at my witts end here. I'm gonna try a new alternator and see what that does.
Do these ammeters go bad? I'm pretty sure the ammeter is a very simple mechanical coil or metal loop that just physically moves a needle. I dont think they go bad unless they get shorted out. My ammeter returns to middle of gauge when the car is off which is what it's supposed to do
At this point, what about running jumpers to everything charging related? I'd be curious if it still acts up. If it doesn't, take each jumper off and hook up the stock wire till it acts up
As far as ammeter, they can to the point they can't handle the current, and really can cook the wires. I believe you drop tested AND bypassed?
You definitely have a crazy one here
