Try the headlights?Well it brought the voltage drop from 0.9 down to 0.2. Didnt seem to make a change in my bad idle in drive and the ammeter is still acting sporadic, especially at low rpms
You say you did a temp by-pass at the ammeter. Guessing it's wired back up. That's why I asked about the connections being tight...and not touching ground anywhere.But no matter what RPM I'm at the ammeter still acts funny and the lights flicker/pulse in brightness.
I dont think mine has a ground cable at back of engine but my battery is grounded to both the engine block and body and it seems that there is no voltage drop on the ground side there.I've been assuming you drop tested grounds too? Alt to ground? Battery to engine and ground cable in the rear of the engine?
If you look at the wiring diagrams, red wire from firewall to the ammeter. Black wire from the ammeter, goes to a point in the harness, and 3-4 other wires feed from it. You can trace each of those wires, seeing where they go. Those wires are soldered together, and that joint can be corroded. One supplies power to the ignition switch. Switch good, or not so good?
Simple test on any length of wire, besides ohms, is see how easy it will flex. If it feels stiff, there's a chance the wire is corroded. Corroded wire will not let current flow as it should.
It's not all of it, but on your headlights...are the bulb connectors clean, and good shape? How about the ground wire, at the radiator support, for the headlights?
'Somewhere' your getting drag on the power feed, to 'everything' under the hood. Keep in mind, the power feed moves through the firewall (block), to under the dash, then back out to the various places under the hood.
Wild guess, all your electrical problems, are bad connections.
I'm a little confused on what you did with the charge wire, why did you take the red wire out of commission?
Thank you. I'm not really trying to bypass my ammeter. I'd like it to just work correctly.Alternator charge wire, black, goes into the cabin, feeds power to multiple things, then to the ammeter. Red out from other side of ammeter back out to starter solenoid.
When I ran the charge wire direct to the starter relay, I wanted to eliminate the ammeter. I still needed power to go into the cabin.
So, taking the red wire from the starter relay and plugging it into the bulkhead where the black alternator charge wire was, gave me power to the cabin.
I would change that dimmer. I'm not one to throw parts at stuff, but it's inexpensive and that issue with the high beams sounds familiar.
Just an fyi, in my vibration issue thread, I failed to find my issues over and over.
Keep at it.
You have a stator getting hot and causing a short in the alt. Start the engine then take the main feed wire off the alt and cover it up so it doesn't hit anything then go drive it and see if the problem is gone.Well the local alternator guy may have made the problem worse. He didnt have one of the old type of brushes that my alternator used so he modified another one. I saw him do this and thought he knew what he was doing...
Just installed the alternator eith the new modified brushes he installed and now the problem is much worse and it leads me to believe this whole problem is in fact related to the alternator or some kind of charging system failure. The amp gauge is more sporadic with random jumping and now the car will just immediately start to shudder and stall out when I put it into gear.
I'm gonna continue to check wiring but I'm thinking of just getting a rebuilt alternator from napa and seeing what that does, if it doesnt do anything I can always return it... I really wanted to be happy with this local alternator guy but now I'm not sure.
Alternator...voltage regulator...you will not know, until each are tested. IF they test good, the problem is somewhere else...I'm thinking my alternator is failing but my voltage regular is working ?
For some reason my engine to firewall ground strap is missing. I have a good solid ground that goes from battery 》inner fender 》front of engine block so I'm thinking that is probabaly not cause this. But I will get a ground strap on there anyway.Alternator...voltage regulator...you will not know, until each are tested. IF they test good, the problem is somewhere else...
And, how are they 'connected'...wires. Unless ALL the wiring in that charging circuit, is in good shape, it can't do what it's supposed to do.
Again, I'm no dang expert on anything electrical...but, I know basics, on how things work. Your service manual can tell you how things work, and how to test 'em.
First, that 65 amp alternator should be plenty for your 64. Yes (just wiring basics) you should have the engine to body ground strap in place, with good connection. Should be a self-tapped bolt hole on the firewall, under the voltage regulator. Ground strap from there, to the backside of the passenger side head.
Even if the car 'starts' right up, does NOT mean your ignition switch is ALL good. The start 'circuit', that goes through that switch, is completely separate from the other circuits that go through that switch.
The ignition switch would need to be completely tested, for each circuit, before calling the switch good. Yep, the headlight hi/lo switch can be checked, too. Simply with an ohmmeter...ohms reads 'resistance' in the wire...more resistance, the wire will not carry the load it should.
That charging circuit, not working right, is your main problem. You want to find out why. It all needs to be checked, down to every inch of wire.
50+ year old parts, remember? They can only last so long, then they need help.
Pretty sure your problems are not, just at one point. At least a few.
If you follow the wiring diagrams, headlights and ignition switch, the answer is yes. A good chance it's in the wiring itself. 'Power' goes to both the ignition switch AND the headlight switch. If there's resistance in the wires...guess what!Could headlight wiring problems or problems with my igntion switch be causing that issue?
That can be related to wiring. Too much resistance, low power feed, poor performance. Have you tried changing the ballast resistor, on the firewall? It's part of the ignition system.My main issue is this stalling and bad idle.
I broke down, and looked in the book. Trouble-shooting the ammeter, the only thing said is 'high resistance in the field circuit, or voltage regulator not adjusted right.The car is definitely charging to some extent but it's just acting funny at the ammeter
New ignition switch did not fix it. A voltage drop test is a very similar test to a resistance test. Bas9ically instead of measuring resistance when the wire has no current passing through it. You measure the difference in voltage between two points on the same side of a circuit while the system is under load (such as car running or a switch on.)The reason I was told to so a voltage drop instead of a ohms test is that supposedly wiring can sometimes pass an ohms test but then fail a voltage drop test. So a voltage drop test is actually better at showing you if voltage is getting "stuck" anywhere in the wiring or electrical system.It's TOO easy to do an ohms test on wiring. From end to end. On the meter, set ohms to 0 -100, and test the wire.
On mine, I gave a limit of 0.5...maximum...if more than that, I replaced the wire.
