As best I remember, the 4 terminal ballast resistor's wiring harness, on the inlet side to the resistor has an orientation projection, that matches the ballast resistor's connection, that connects the resistor correctly, to the 0.5 ohm (coil's feed connection) and the 5.0 ohm ECU's supply. Since your ECU, has only 4 pins, the origional harness connector with 5 wires will fit but the 5th wire that goes to the 5.0 ohm part of the ballast resistor will not be connected to anything.
With the ignition switch on, but not cranking the engine, there will be approximately 12 -13 volts on one side and the ballast resistor and approximately 8.0-9.0 volts on the other side of the same section of the resistor. Since the 5.0 ohm section of the resistor is not in the circuit, the same voltage will appear on both connections and no voltage drop will be noted. On the 0.5 ohm section that feeds the coil, there will be a voltage drop and the resistor will get very hot to the touch....this is normal.
When cranking the engine, the ballast resistor is bypassed, applying full voltage to the coil, approximately 12 volts, to produce max spark energy during cranking. The transistor on the ECU, is normally biased ON allowing current flowing to the coil. ITS WHEN THE TRANSISTOR IS TURNED OFF, by the internal components of the ECU and the pulse generated by the magnetic pickup coil in the distributor, the coil generates the spark. As soon as the engine starts and the key is released, the current flows thru the ballast resistor thru the ECU's transistor to the coil. The reduced voltage to the ECU and coil helps to reduce the heating of the components and extends their life.
IMO....if your car started and ran b4, but not now, suspect a failed ECU. Insure that the ECU is securely grounded, as the ECU's transistor must be grounded to allow the coil's primary current to flow.
Just my opinion of course.
BOB RENTON
