- 2:16 PM
- Jul 1, 2015
The ballast resistor limits the current that the ECU/MODULE must switch. The module turns OFF the coil's primary current to produce the spark then IMMEDIATELY turns ON the coil's primary current or dwell time for the next spark, limited to the amount the value of the ballast resistor allows. During cranking, the ballast resistor is bypassed allowing full voltage and current to the coil, to produce the spark. The pickup coil in the distributor furnishes the WHEN, the spark is to occur, the ECU, simply does the on/off switching.
Are you sure the distributor is in the correct orientation with respect to the firing order. The distributor rotates COUNTER CLOCKWISE and the firing order is: 1-8-4-3-6-5-7-2 with the.even numbered cylinders on the passenger's side and the odd numbered cylinders on the driver's side.
It sounds like to me that POSSIBLY the wires are orientated incorrectly. DO YOU HAVE A FACTORY SHOP MANUAL, as it explains the correct distributor and plug wire orientation, to review your installation?
Just my opinion of course.....
BOB RENTON
BOB RENTON
