99ss
Is all I have to do is buy a new distributor to have electronic ignition?
The distributor on this 440 moves quite a bit while the engine is turning over, I think its worn out and needs to be replaced. Whats the easiest way to do this? MSD or is there a factory option that is cheaper, used part somewhere? I want to make this 440 run for a while. I am going to restore the body and interior before putting an engine in it. The current 440 seemed to run decent but I cant get it restarted.
background... car has a one gallon gas tank under the hood with an electronic fuel pump taped to it. The guy couldnt get it started and decided the gas was old and lines maybe clogged so he rigged this up to make it run.
It ran and we drove it off the trailer but I cant get it restarted and am doing the investigation now. I have a mechanical fuel pump coming for starters. I bought a cap and rotor and tried to buy points and condenser but of course they didn't have them and need to order them. BUT someone suggested just going electronic instead.....
advice?
thank you
advice?
thank you
