wedge5
67 B-BODY: Thanks for the diagrams BUT I am lost? I am kinda dense sometimes!
Why am I stripping the wires going to the distributor?
Why does the coil say Black(+) and White(-)? Am I hooking up the white wire from the box to the (-) and the Black wire to the (+) instead of the Orange(+) and Black (-)?
Do you have or could you show me a diagram with the ballist wires going where they need to go? I kinda understand your instructions but they are kinda of fuzzy also. They could make sence when I go out and look at it but as now I am kinda confussed.
65-440: You wrote in an earlier post: Ballist Resistor completely eliminated........unless.....You are running a factory charging system, one of those wires comes from the resistor to the alternator voltage reg.
What do you mean by factory charging system? I have a PowerMaster Alt. I am not using the factory amp. gauge in the dash. I am using an Autometer volt gauge. I am not using any factory gauges. Battery in the trunk hooded up to a master cut off switch.
