Embarrassed: one lug nut won't budge
Thanks for the candle trick, but won't work here as the lugs cover/cap the stud threads.
Breaker bar not shown in picture, but I did try it.
PB Blaster can was decompressed. I shot TriFlow on the drum and soaked the lug cap.
I'll let you know this week.
Have not had this much fun since 1997.............
Wonder if you want to sacrifice the lug nut by drilling a hole in the end and enlarging after a smaller starting hole. Then use some of the tricks suggested?????????????????
According to receipts Discount Tire put tires on in 2015.........
If that's the case, then the thing could very well be cross threaded . . . and the only way to get it off it to break it off . . .
Studs and lug nuts are cheap....go ahead, swing until it gives way. :thumbsup:
x2....put a longer pipe on your breaker bar and go easy. Good luck:thumbsup:
From my experience, Discount Tire is very careful about torque. They use an impact with a torque stick and final torque by hand with a torque wrench.
Quick question: My Chilton manual (purchased by me in 1979) covers 1969 to 1975 Charger and Coronet. Assume it's a good book for the brakes on the 1968 Road Runner?
My opinion on a Chilton is they can be very generic. If the illustrations look just like what you are working on you should be good. So many times they will explain how to do things that actually covers many vehicles and not just yours in particular. I like to use the Motor Manuals or the service manual for your car by Chrysler. Should find one on Ebay or Amazon.
Tip on doing brakes: Take one side off at a time so you have the other side to go off of when reassembling.
On big off road trucks when 1" air gun is in avail we used a braker and a pipe then drove the truck till it was firm ageist the ground then went a little further they will come off this way but be extremely careful slipping is a bad thing especially for a restored car or your face . I would just brake it the hell off sounds to me like it's cross threaded typical of these tire shops
YEP a lesson I learned in my younger days.
Right now I'm 'car poor'. Otherwise I would not fool with these drums and just start my disc conversion.
Saving money. Should be converting to front disc Christmas 2017!
If it's the driver side, what is the chance that the tire tech didn't realize it was left hand thread, broke off the stud, and replaced it with a right hand stud and didn't say anything? For this reason, I won't let the guys touch my wheels, I show up with my own tools and take off and put back on the wheels myself.
I should have suggested to grind off the end of the lug nut to expose the threaded part of the stud, then the heat, liquid wrench (or whatever), long breaker bar. Impact wrench with compressor pumped to the max pressure. The stud will break with a long enough breaker bar/pipe, although I have broken a couple of cheap impact sockets too.
How about using a cutoff wheel to partially split lug nut. Not much room to grind.
That sounds extremely dangerous, all this fuss over a lug nut, cut the damn thing off.
I agree on something like this cut it off on the big trucks this is much easier but just giving options I'd just bring the car to a local big truck shop and let them zip it off with a 1" impact that will do the trick
