Understood. Can't see the studs as the lugs are caps.Most left hand studs will have a "L" stamped in the end of it.
Google searching seems to lean towards RH h/t meaning Right Hand Threads. Assume studs were converted?
I was 20 years old in '85 with zero Mopar knowledge when I bought my GTX ......... I think I broke off 3 before I figured it out
You'll find out working on these pieces that "there's always one"! You can have just two bolts or nuts to remove or twenty and there will be one that will give you a fit. Comes with the job.Thanks. Life is good. They are right hand and all lugs came off easily!
