- 2:50 PM
- Jul 31, 2011
- Western Colorado High Desert
I just went to the Chinese store and got a couple of those $12.00 dollies.
It looks like I will be RErebuilding my 440/493. The flat tappet MP 528 solid cam lost at least 3 lobes and I just can't risk further damage by putting in another cam without first pulling the engine and cleaning it all out. This situation would be a real pisser but it gives me the opportunity to make a few changes for power and reliability.
Last year, I swapped in a Tremec 5 speed. I have never done an engine R & R with a manual trans. I am thinking that I'll pull them together and reinstall them together.
Because of this, I am going to do a "body drop" installation and maybe even a removal.
I plan to make some sort of cart or stand with casters. I will fab and weld something together so that I can wheel it under the car, lower the car with a car lift and bolt it all up. I might make the transmission section "bolt together" to make this thing easier to stow or transport.
I would really appreciate some input and pictures if possible. I don't know how tall to make this thing. I'd probably need to make it adjustable so I can use it with other arrangements, I.E. B body B/RB with A/T, A body LA with 904 or 727.
Show me what you did!
Thanks!
They say you should break the cam in with light springs or that will happen. I built my current motor before hearing that, so I'm getting ready to pull the valve covers to remove the inner springs for break-in. There's a Youtube from Uncle Tony on cam break-in.I ran good oil. I have been using Redline 10W30 with added Zinc for over a year. I always added Comp Cams break in supplement at oil changes. Maybe the valve springs were too stiff? I kept the same ones I had with my last cam, a Lunati solid with more lift.
I bought the cradle from u.s. cartool. I took the easy way out. I'm so ashamedIt looks like I will be RErebuilding my 440/493. The flat tappet MP 528 solid cam lost at least 3 lobes and I just can't risk further damage by putting in another cam without first pulling the engine and cleaning it all out. This situation would be a real pisser but it gives me the opportunity to make a few changes for power and reliability.
Thanks!
Here is my cart. Bought some 400lb rated swivel casters, the rest was just scrap steel I had. The two front vertical posts fit into the openings on the k, back portion matches up with the trans pan. I got some 5/8x12" bolts to use as guides up front when mating up, cut the heads off. Works great. I can leave the headers on too.
