PurpleX
Hey all, having a problem with the engine running on and dieseling quite bad when the ignition is shut off. The car runs rich to begin with, idles fine at 800rpm. Aside from rebuilding and checking the adjustment on the carbs Im looking for some suggestions. Its a 1969 Hemi, all stock, dual Carters, timing is at TDC on 91 octane fuel which is the best available here. Need better gas maybe?
Thanks.
Thanks.
