Wietse
But in general, those aux. drive can be classed as load right, same as a tight converter does once in gear?
I am fishing out all potential inconsistencies, I installed a new timing chain kit and immediately after start up noticed it ran quite better.
As time goes by there will be some more slack on the chain and it can degrade again but it 100% improved.
Next is to install a stopper bushing on the distributor shaft that will act as a stopper for the intermediate shaft (pump drive shaft) to float upwards and cause ignition timing deviation.
I also have a set of Rhoads variable lifters lying that I still want to install as well, this to take out some cam duration.
I just have a little fear over running new lifters on the existing camshaft.
