If you do suspect a head gasket leak the simply get a test kit for the presence of hydrocarbons in your coolant. Cheap ... simple ... effective.
ok, so pulled the water pump, brand new and spinning easily. Looks to be the hi volume one as it has the larger impellers?. Bottom radiator hose hasn't collapsed and it has the wire core. checked the stat again in hot water and worked again. Put it all back together again started up and within 5 mins the motor was red hot, the coolant at the top of the radiator was hot...opened the tap at the bottom of the radiator and the coolant was cold...? pulled the damn stat out and ran again.....ran perfectly at around 140-150....and only went to 180-190 after it was shut down for a few mins...gonna start it again this arvo and let it go for awhile without the stat and see what the temp gets to again....just ordered a hi flow milodon stat. So we'll see how we go later... thanks for the input guys!
OK, the you should have a simple spring loaded pressure cap without the two way valve.yep the overflow that spills to the ground
