engine size
about 452. Boring should only be done if necessary and not to acquire cubes. If you want more cubes, stroke it.
And Stroke good.....440 - 493 stroker kit - crank rods pistons rings etc..plus .30 over = ??? anyone :)
Cubic Inch Formula is bore diameter (Inches) X bore diameter (Inches) X # of cylinders X length of stroke (Inches) X .7584 = total cubic inches example a 440 is 4.32" & 3.75" stroke & 8 cylinders, std bore 4.32" so a 0.060" over would be 4.380" bore X 4.380" X 3.75" stroke X 8 cylinders X .7854 = 452.02283 cubic inches.... Happy Big Block Moparing...
4.35 * 4.35 * 8 * 4.15 * .7584 = 476 ci? how does that work with a supposed 493 .030 over? 476 is what your formula comes out to? that would be under what it's supposed to be.
his formula bore x bore x stroke x number of cyl x pie squared is correct.
One thing missing Bore/Stroke Ratio (B/S)
Cylinder Bore Size 4.35
Bore/Stroke Ratio (B/S) 1.0481927710843373:1
Piston Stroke Length 4.15
Number Of Cylinders 8
Cubic Inches 493.4083319966887
Ah I found the problem with your formula....took me a minute, it's .7854 not .7584...but it works.....had me getting heated thinking I got ripped off! lol
Oops
DOOOOOOH!!!:iamwithstupid:
