Dk440
Was supposed to be a perfect day at the annual Cruise and Meet, but ended in frustration and a tow truck ride!
It was 90 degrees out, so I was a Little hessitant at first, since I have been struggling with overheating issues, as soon as the outside temp. was above 80 degrees, but desided to go anyway.
Made it to the meet ok, and after a few hours, decided to head for home - never taking my eyes off the temp gauge which kept just below 200.
After driving for approx 20 min, I removed my foot from the gas to stop at a red light, and instantly the engine died!
I tried to restart it, but it could not turn over and now the temp gauge showed 240 degrees!? So, I called the tow truck. After cooling down for 30-40 min, the temp now was 170, so I gave it a go and cranked the engine. It reluctantly fired up but squeeled like a pig, so I killed it instantly. Tow truck came, and took us home. Fired it up the next day when Cold, without any knocks or sounds...........!?
So my question is - what should I do. I am pretty sure, the pistons got stuck in the chambers due to the heat........and that can not be good. Yes, the engine runs, but would you take it apart now, in order to avoid it blowing up at a later stage?
Drained the oil, and it seems to have metallic dust in it + it smells burnt.
Talked to an enginebuilder, and his recommendations were to strip it and rebuild it asap. It makes perfect sence, only he wants to make Money, so therefore your thoughts are much appreciated.
Engine is a reworked 440 with purple cam, roller rockers, Performer heads, dual carb ( 413 Clone ).
Thank you.
Rolf
Thank you.
Rolf
