No, NOT lightweight springs. If you are going to use VA connected to manifold vacuum [ a veeeeeeeeeeeeeeeery good idea ], then you will have a lot of timing at cruise & lower rpms.
If you put light springs in the HEI, you will probably have too much total timing. This may cause detonation. Total timing at cruise is initial + VA + part of the centri curve. The engine doesn't know the difference, it just sees the total amount of timing. So if you have heavy/std springs, leave them for now until idle, cruise & WOT is sorted. HEI, great choice!
