bandit
Hoping to get some insight on one. Last week I swapped out my header gaskets for some copper ones. Have no idea if changing those is related but yesterday at right about 5k rpm (first time I pushed it up there since gasket change)the sound tone of the engine all of a sudden noticeably dropped down and it felt like the engine just smoothed out from it's normal rumble/vibration. Happened all of a sudden at 5k and not a gradual change. Did it twice yesterday when I pushed it up there.
Some things to note:
-It never did this before.
-I also checked and tightened manifold and carb bolts last week
-had spark plugs out at same time and they looked good.
-not sure if it matters but had to take off valve covers to get to header gaskets
-I get coolant loss through header bolts when I have to remove them so had to drain and refill some coolant when I did the gaskets.
Other than that, all is the same. Been doing some reading and wondering if this sounds anything like the start of valve floating? Just taking a stab here. It is raining today otherwise I'd have it back out listening to it again. I let off the gas a second or so after it happened so not sure if I am losing power at the same time. One thing I want to get back out there and see.
