kb67mopar
It sounds like you found the problem. Poor connections like that may still produce spark but sometimes weaker which would make it run great at low speed and idle and then when the cylinder is loaded it could blow the spark out (essentially) and cause it to completely miss. It is amazing how much that 1 cylinder can do.
good luck and keep us posted on the result.
PS.
I HIGHLY recommend replacing the whole set of wires immediately.
PS.
