Compare to my 360, 9.0-1 compression, ported factory head, 220@.050 hyd roller, LD340 intake, 650 Holley DP, TTI headers and 2 1/2" TTI exhaust. It has the same close ratio 4 speed, 3.55, Challenger. Motor might make more than you do. But you'll get the idea. With Radial T/A's I walked it to a 13.20@105, once. Other times it could be high 14's. With drag radial's 12.70@107. With slicks and a 4.30, 12.50@110. The other thing that will slow you down is how fast you can shift the 4 speed. These times were made with the throttle full on the floor the entire time. Pull on the shifter hard and then just tap the clutch to get it to come out of gear. The 3.55 with the 2.47 1st gear is tough. Very little starting line ratio, only 8.76.
