Estimated 1/4 mile - 71 Roadrunner 340 4 speed
4.10s are a miserable street gear if you have to travel any distance unless you have overdrive or live where you won’t be traveling over about 55 mph sustained. 4.10s without overdrive are not modern traffic friendly.
Any Dana 60 from a truck is going to require narrowing and car style bearing ends to be installed to run car axles and brakes.
Travis..
Ok, is there any way really to figure out what your final compression ratio is without peeling off the heads? I know about the compression testers that screw into the spark plug hole, but am unsure how the psi would convert into a compression ratio
As for boost, a stroked out 426 small block with a roots blower sounds nice, the fiberglass hood ill get so I don't chop up my original would also save a bit of weight..
Now wondering, why do you say don't go deeper than 4.10s, specifically on an NA build though? Would you say the same if I went with a 28 inch tall tire
The dana 60 was always a thought in the back of my head, also easier to since I can decently easy find limited slip 4.10 versions of the axle from trucks, and I believe I can use my brakes I already have if I'm not wrong
At the point of split monoleafs and caltracs with adjustable shocks, I'm gonna probably be in around 2 to 2 and a quarter grand. Is it really worth it to keep leafs instead of going to 4 link?
You don't need cubic inches with boost. Bigger dispacement engines that are boosted just become harder to hook up out of the hole. Roots blower build heat and are usually not a pump gas thing. Turbos and belt driven centrifugal superchargers can fit under the hood and are usuall pretty efficient. They din't have the wow factor and roots has.
When you do a compression check, you have your cam information. It will tell you the health of your engine and you can use online calculators to estimate your static compression. It won't be exact..but good info.
The last Split mono's with caltracs I bought were around 800 bucks and is just a bolt in. Shocks you need no matter what. Not sure which 4 link your referring to. Some bolt in the stock location while the other require heavy body modifications.
We have narrowed Pickup dana 60s with a 3inch tube. We are running split mono's and caltracs. There is no pinion snubber mount, so you have to go with some kind of traction control. Or just buy a s60 new and drop it in.
We run 4.10s with 30.2 tall tires. 28's would still work. Any deeper gears then that we swap pigs for a race. Quiet exhaust helps tolerated 4.10s. 3.90s would be similiar to our gearing w 28s.
4.10s are a miserable street gear if you have to travel any distance unless you have overdrive or live where you won’t be traveling over about 55 mph sustained. 4.20s without overdrive are not modern traffic friendly.
Travis..
I dailied 4.10s for a while in the roadrunner, it was surely a pain in the *** on the interstate but I personally think that tradeoff is worth it
Well, I knew that about the dana 60, the plan was to take it to a weld shop or drivetrain shop that did axle narrowing to have it to OEM spec mounts and length, then install my brakes and slap it in after having the driveshaft shortened, it really doesn't sound that difficult since I'm not going with custom length but that might just be my overconfidence talking
Ok, it sounded like you were talking swapping your brakes onto a truck axle without needing the narrow job. You got it.
Travis..
Ok, i was mistaken, as i thought the leafs were sold individually and not as a pair. I was referring to the qa1 4 link by the way, but now that I see the new price it doesn't seem too terrible.
Yeah I ran around with my 4.10s, I didn't mind as much but I always ran around on big trips with a earbud in for music/Waze. One ear bud was left out so I could have some situational awareness, mostly the radar detector I run
Eh, honestly turbos just ain't my thing, I'd honestly rather have nitrous and more cubes over turbos or a centrifugal. The big reason is I don't wanna swap over to a blow through or EFI now that I've heard everyone's opinion about it, but also it just clutters the engine bay.
Secondary note, now these days I'd say turbos have more of a wow factor instead of a roots, not my personal opinion but based off of every person who just thinks twin turbos are Gods greatest inventions and nothing else makes any power at all at car meets. God i can't stand those people along with the LS swap the world people and the "why don't you swap a modern drivetrain" people. Sorry for the tangent
I also guess a compression tester is in order, so I can finally figure out at least my rough compression ratio
I hate LS swaps.
I hate LS swaps.
They have a place, but that place sure as **** ain't in a classic American car. I wouldn't think twice though if it was some Japanese car that originally had a 4 banger or a rotary. I think a cammed stroked NA ls swap miata would be a riot to whip around before died wrapping it around a tree cause I accidentally tickled foot on the gas during a corner
My favourite Mopar a 71 Runner!
A fellow UK Moparmate had a 72 340 4-speed too.
He ran that down the track on may occasions at around 14.00.
Its now an auto with a 408, so that's where you end up I guess?
I have a 71 GTX that I hope to run in Superstock UK this year.
What do I expect?
Same as my 70 GTX mate from the 90's, Mid elevens or he will rib me bad!:praying:
