Haha, I think so...I have no idea about the taxation, social and economic issues with Ethanol, but from a technical point of view it's an excellent fuel...cooler engine, more power and cleaner exhausts...the bigger the Ethanol mix, the better in my opinion!Well, I see this thread ended up in the political forum.....
So tell me what's wrong and why it's wrong in my statement. I really look forward to that.Now here is a good example of someone that doesn't know what they are talking about.
Ethanol is alcohol and will attract/ absorb water into gas resulting in phase separation of fuel. Ethanol reduces self life of gas to about three months. Long term, ethanol will deteriorate components made of rubber, aluminum, etc. That means fuel lines and carburetors. I drive a 2003 BMW M5 to work everyday and it's surprising how my MPG goes down when I use ethanol fuel. While I don't see much of a difference in performance the MPG does go down. Of top of the bad effects of ethanol it takes a lot of water to grow corn. With the water supply shrinking in the mid-west it really doesn't make sense for the long term. I have to mention that we are paying much more in food prices since we started burning corn in our gas tanks. On top of it all ethanol is subsidized by the government which means taxpayers are paying for it twice. The only reason we have ethanol in the U.S. is because corn companies like archer daniels midland have gotten smart and started giving money to both dems and republicans. More could be written but the bacon is ready
So you are just broadly echoing incorrect rumors.
There is one rubber type that doesn't fit well with E85, that's natural rubber. Where is natural rubber used nowadays? All other other rubber types work well with E85.
Aluminium is slightly affected by E85, but the impact is so small that aluminium can well be used with E85. I can supply you with details about the compatibility of E85 and hundreds of materials.
Of course the MPG goes down, E85 and pump gas have totally different air/fuel ratios. If your car is unable to adjust the engine to correct air/fuel settings, of course it won't run well.
In terms of power, again, if your engine management is unable to adjust to the correct settings, your power will be down. If your engine management can fully adjust to the ethanol contents, you will have more power than with pump gas. I can show you how to calculate it if you want.
By telling people they don't know what they are talking about? Show me some evidence that you know what you are talking about. So far you haven't showed any.... But I do respect other peoples opinions.
Actully Cranky it did not end up in political forum it should be in the common sense forum!!!!!!!!!!!!!Well, I see this thread ended up in the political forum.....
It did get moved and I asked Joey about if my first post had political content or was it the replies that got it moved. I guess he reviewed it and moved it back out.Actully Cranky it did not end up in political forum it should be in the common sense forum!!!!!!!!!!!!!
Why not run straight alcohol? Do some research on it and you might find it to be a better alternative....E85 is nice for high cylinder pressures. The shop I help out at has a 461rwhp 2011 Turbo Hayabusa that runs on it. Zero detonation and that is with 11:1 dish pistons and 26psi boost. The 93 octane tune was only able to hit 8psi before detonation.
I was thinking of running a 14+ :1 440 based engine jetted for E85 in the future.
