Exhaust 3" vs 2.5"
Malicious, hears a good read and explanation...
Destroying a myth.
Some say that "an engine needs backpressure to work correctly." Is this true?
No. It would be more correct to say, "a perfectly stock engine that cannot adjust its fuel delivery needs backpressure to work correctly." This idea is a myth. As with all myths, however, there is a hint of fact with this one. Particularly, some people equate backpressure with torque, and others fear that too little backpressure will lead to valve burning.
The first reason why people say "backpressure is good" is because they believe that increased backpressure by itself will increase torque, particularly with a stock exhaust manifold. Granted, some stock manifolds act somewhat like performance headers at low RPM, but these manifolds will exhibit poor performance at higher RPM. This, however does not automatically lead to the conclusion that backpressure produces more torque. The increase in torque is not due to backpressure, but to the effects of changes in fuel/air mixture, which will be described in more detail below.
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
If your racing the car, the 3" mandrel bent system is very good flowing.
I went from really loud 3-1/2 dual system with Race bullet "mufflers". The car was way too loud for anything but the track. Went with 3" TTI H-Pipe system with the superturbo mufflers and I did not see any loss in performance when I had the 450 RWHP setup. I'm using the same exhaust with the 500" stroker, 560 RWHP. I have not run it uncorked, so I don't know if the exhaust is hurting performance. Compared to other cars at the track, it is quiet. I would say the sounds level is about right for a street/strip car, but too loud for a daily driver. I am putting a TTI 2-1/2" X-Pipe exhaust on my Convertible with a 550 HP 505" stroked 440. I'm using the 2-1/2 size because I want a quieter exhaust. I am not using the superturbo mufflers that come in the kit, I have some larger case, walker quiet-flow mufflers that are going on the car.
I'm running a 3" TTI system all the way out with noisemasters and I don't even bother uncorking the 2" x 3.5" Hookers at the track. My car runs 12.80's with slicks. I never tried it uncorked but without proper extensions it may not be a fair comparison.
The wave that travels down the pipe has been studied for nearly 100 yrs and has a huge effect on engine tuning. I have a very good book written by some MIT guys that set up testing jigs and measured the pressure wave using a manometer timed to the engine. Using a single cylinder engine as the test bed they concluded that the adjustable sweet spot is fairly narrow (about 1000 RPM) and the ideal pipe length to cover all RPM ranges is 54 feet. Fascinating!
I just have to give props to Meep Meep for posting "noisemasters". That is the best one I have heard yet.
