Nate S
Converter too tight.
Not doubting that at all. The initial question holds though, when stock it would have had this converter too and I believe it should have roasted the tires. Converter may help but if it won't roast them there must be something else.
I assume the CH4B is the intake? If it is a single plane it will be a bit less responsive down low and may well need a looser converter.
Yes, the intake. An early RB dual plane. Similar to a '70 cast iron with slightly larger passages.
