benno440
thanks buddy been a great help along the wayKeep pluggin dude. These are really small bumps in the road. You'll get there. I got faith in you.
There is also the Spicer 1330 joint to put in the mix. That one is ID'd by the retaining clips on the outside vs. C clips on the inside. They also take a different yoke than what would be used with a 7260 / 7290 joint. This 1330 is found on Dana equipped cars and 3/4 ton trucks.
The 7260 / 7290 locates on the inside of the caps (C clips).
The 1330 locates on the outside of the caps against small tabs on the yoke. Uses U bolts as a retaining system.
If your driveshaft don't fit, ya need a bigger yoke:sign17::hello2:
p.s. Sorry, I couldn't resist.
Thanks for posting the detailed info 68 Sport! I think I was looking for the 1350 number when I mentioned 1360 and 90, so disregard the above. I meant 1350.
The straps are just fine because if you look closely you will see the yoke material extends beyond the centerline of the U joint and that is what carries the load. The strap only keeps the driveshaft from pulling forward. Same idea with the U bolts.
I only mention the straps because that's what my car had when I bought it 3 yrs ago. I kept hearing a clunk-Bamm! Then I looked under the car and one of the u-joint strap bolts was completely gone! Good thing I looked! I like the U-bolts better because to me it seems more secure and less chance of the nut backing out than the bolt backing out from the strap like what happened on mine, although the reason that bolt was missing may have been due to other thing wrong with my u-joints/clips, etc.
I used to run an 8 3/4" with a spool in my Corvette drag car. It used the yoke with straps. The car had lift bars (similar to ladder bars) and coil overs. 14X32 Goodyear slicks, 6.38 gears and 9,600 rpm starts. Pulled the wheels high enough to get me to invest in a set of wheelie bars. My point? Never lost a ujoint or strap. Go ahead and use them...
