- 4:04 AM
- Jan 14, 2009
- Shoreline, Washington
Need? No, not really. The advantage of running a higher than stock capacity alternator with stock loads is the higher output at idle engine speeds. Where the idle performance of stock rated alternators is quite low and not capable of keeping up with multiple stock loads at the same time at idle. Current is then drawn from the battery (discharge), contributing to more unnecessary current stress to the charging system wiring and components.So once i by pass the bulkhead terminals would i need a bigger amp alternator with the factory A/C,lights ,radio all running at once or would the standard alternator be sufficient.As those options would be on the correct side of the charging system.Also I'm wanting the car to look factory correct could i pass the straight run wires through the bulkhead plug so it looks standard i was thinking drilling the hole larger on the bulk head plug so the wire passes through cleanly ? also do i need a fusable wire going through the bulkhead or better to have a 50amp circuit breaker under the dash would that be okay ? sorry for the million questions
