Fire Recovery 69 Charger- TKO600, EFI, Rack&Pinion,etc
thanks guys!! i appreciate the encouragement its tiring working and working on this car. this has been a never ending drama with this car... hope its all worth it in the next few weeks..
well i had another problem with her... she wouldnt quite crank over... like the batt was dead... and i was running a optima yellow top in the trunk of the car. then i took one of batteries out of the diesel i got and same thing. so then i checked my connections and noticed the ground wire from the batt in the trunk to welded stud in the floor of the trunk was HOT!!! so i checked my grounds and thought i had good contact on ground strap from the engine to the fire wall but i didnt cause i took my dremel and cleaned up the block and the firewall. rehooked er up. and turned the key and she started right up ;)
if i can get her to power tour i will get another thread going with pics and GoPro videos.
heres a quick video... pardon the messy garage
http://www.youtube.com/watch?v=tqhG2n0DmUc
talked to classic auto air guys yesterday and they gonna make me up a hardline for the a/c line. heres some pics of mock up
and the billet panel we made to hold the billet switchs for the lights and such.
Got home from work tonight and finally got everything done under the car so I could set back down on 4 tires for the first time in 3+ years!!!
Before
After
And just because
Gonna try and get her outside in the am for a bath and a garage clean out!!!
Sounds great.... bucket T - bucket T - bucket T - bucket T....LOL... good luck in the near future, keep it going, your looken' good
Ran out of hose.... $62 later of 15' of jegs push loc hose....
AN is retarded expensive.... But worth it? Yes.... I guess. Don't wanna redo it....EVER
Gonna try and get the ac hoses crimped today
well successfully did the hot rod power tour... ripped a hole in my oil pan twice though :(
here are the pics from the tour
right after oil hole #2 happened to find a die hard mopar shop that took my pan off and welded it for me
An amazing build. Watched your videos. First time out for me was quite a thrill. Glad to see you treating it as a driver.
