I worked the summer of 78 with my Uncle who was a front end mechanic at Jack Clark Dodge. Frank always bent the long side of the cotter pins over the studs leaving the short side straight like the unrestored photo above.The wifeee has me doing the wife tied.e weekend....lol
So when I get a chance I will post some current progress pics showing the bent cotter pins....I have researched survivors through the years and my own survivors, look at my previous suspension pics on the X prior to restoration...all cotter pins are natural steel and bent up and over the ball joint studs. Also think about time which is faster on the line bend or the stud or separate and bend the two around?
Same way the factory did...It was easy, effective and quick....Also easier to remove if needed...I worked the summer of 78 with my Uncle who was a front end mechanic at Jack Clark Dodge. Frank always bent the cotter pins over the studs.
Yes....Are you shocked mine are not installed?Did Mopars have rubber dust covers for the drum brake backing plates?
