Found my answer.....thanks very much...........Need HELP on 383 cam install hydraulic flat tappet....END PLAY?
You're right, the auxiliary shaft turns counterclockwise because it's being driven by the clockwise
turning cam sprocket that is connected by a chain to the crankshaft thats also turning clockwise.
Look at the 45 degree cut on the cam and you can see that it's being pushed rearward.
