Nevada dan
first a rubber gasket with a little soapy water and it should take less then 5 minutes to have it installed, mine had a problem, (68 hardtop ) we had a hard time trying to get the driver side top corner to lock in , (rubber gasket ) , after fighting it for 15 minutes , we pulled it out and got the tape measure , the pinchweld looked great , all factory never been worked, but the driver side corner on the top was a 1/4 inch tighter then the other side , just the corner where it curves in the rest was normal and square we ground the windshield from the corner a 1/4 inch tapering to nothing about 3 or 4 inches from the corner , wind shield went right in no problems since, when I got the car I noticed the lower chrome not fitting , setting out a little, the windshield was not seated right in the bottom because of the top corner, I looked it over good and I'm sure it was welded wrong from the factory , so try measuring every part of the opening like was suggested earlier, something is probably off
