4406bbl
No suprise on the flex, these cars are bad for it. I would quit jacking it up like that unless you want the cowl to crack where the piller meets the cowl. Jack under the rearend, or k-frame only. If you do frame connectors make sure the car is square and level before you start. On a resto that lead seam at the cowl should be melted out and welded solid. I have seen cars put on 2-post lifts show witness marks in the paint at that seam. Every time you jack the car like that or 2 post lift it you over flex those welds, weakening them.
