Nate Yi
I got my car driving for the first time the other day and other than the crazy amount of play in the steering wheel, the most glaring issue was the front tires screeching as I drove down the road. Some friends of mine were said they saw the front wheels wobbling as I was rolling and the car pulls fairly hard to whichever side the steering wheel is turned more toward.
The car also has some weird positive camber angles when it's just sitting on the ground. The steering gearbox won't hold fluid and the shaft rotates when I wiggle the wheels when the front is jacked up off the ground.
What could cause these issues? I know I have to replace the steering box seal as well as rebuild the shaft coupler. I can't afford a full on front suspension rebuild kit as of now so I'm trying to see what I can fix so that I can at least make it so that it's not so dangerous to drive. Pitman and idler arm are also done for so that's going to need to be replaced.
Also, what brands do you all recommend as far as suspension parts?
Thank you!
Thank you!
