gas tank
D man
New Member
10:33 AM
edmonton
Hi Everyone
Can anyone tell me if they know of a gas tank part number that has a return port for a 67 dodge coronet 500 conv?
I would like to install a pressure regulator with a bypass. I have installed a regulator without a bypass and I am not satisfied with the result.
Hi Everyone
Further to my gas tank with return post, maybe easier to replace sender with one that has a return. Anyone know of a direct replacement sender with return?
You could drill a small hole in the unused area of the sender plate, enlarge the hole with a tapered punch, and solder in a steel return line. Aim the new line away from the float.
Mike
Mike
Thanks I may try that
