VitaMeVas
PREPPING/PULLING THE 727 (Part 1):
I slid the GearStar Tranny into the corner of my garage while I pulled out the 727 (for motivation)
Things to think about before you start getting tranny fluid everywhere. 1. Have a tail shaft plug to minimize fluid loss out the rear. I bought the Lisle Kit and believe I used the 1.600"-1.850" plug. Then I bagged and duct taped the plug in place after I removed the drive shaft and disconnected my exhaust from the long tube headers.
2. Disconnect the tranny cooler hard lines and plug them. I put some threaded bolts in the hard line and capped off the radiator connections. GearStar insisted that I use their tranny cooler for the 4L65E without incorporating the radiator cooler (due to it's age and possible debris in it).
3. Disconnect the Throttle Linkage from the carb down to it's connection to the 727. In my application, it won't be used. The US Shift Quick 4 and TPS Sensor will electronically control this. Here's the 68 Mopar b-body manual diagram.
The 'lower linkage bell crank' connection from diagram (above #7) looked like this on my car (below).
3. Disconnect the shift linkage. My shifter is on the column and uses a rod to connect to the 'Z-bar' as others have called it. **see diagram page below** Here's what it looked like in my car. **see below**
-- continued on next thread --
