bigredbird
Red you forgot to leave the address! Geezz![]()
lol, if I see you lurking outside my house with a Dremel tool, Ron, I'm callin' da cops! :busted:
Macguyver could do that :icon_thumright:
I have you all beat...I have a key machine in my basement!!
Yea making key cuts is so easy you don't even need a machine to do it. Even though I own several styles of key machines. I even have a stamp cutter. If you have ever noticed on the right door lock assy you will usually find a 4 digit code. With that code you can look in a book and it will give you the cut depths and make a key without ever having the original. The old pliers and file trick works great and easy also. I have had to use that trick several times in my old profession. (the ever so hated repo man) as I used to say it's not only a job but an adventure and you don't have to join the service to get it. I have NEVER used a locksmith to anything key related ever!!! I have a local lock shop I use to get blanks and it is usually around $7 to $10. for a box of 50 key blanks. It is about time to go get more Pentastar keys so i will be making a trip to get em soon.
yes, indeed... I go to my local Ace HW, as I've done for many years...unless it's 2x4's and sheet rock... It's True Value, Ace, or HWI.
Same here.If these match the originals in appearance I'd been interested in a few sets if you are so inclined to give us a hook up ;)
