- 11:33 PM
- Dec 4, 2009
- Pasadena, Texas
Customer supplying parts and fluid........thanks.
He didn't bring the +4 like I told him to get....brought the Dexron instead. And no on the drain plugmake sure they supply modern fluid
Dexron is way obsolete
+4 has better base stock
or fully synthetic
I'd also disconnect the rear cooler line and see if you get a quart in 20 seconds at idle in N
plugged coolers are common and you do not want future problems to be your fault
is there a converter drain?
Yup, I know that +4 is much much better. And it took me some effort to convince him he didn't want a spool in the rear end for a mostly street driven car. He's learning lol. The rear end is finished and now I'm working on fixing some minor crap and doing the trans.....but now it's it beer 30Well Dexron is what was called for after Type A went away
but it does not like cold and does not like heat and has to be changed much more often than +4 or a fully synthetic
and does not work if there is a lock up converter- tears them up with shudder eventually- which plugs up the cooler and...
