Just a couple of points as far as aftermarket radiators go.
be careful if choosing a 4 row over a three or two row. I had a guy that had bought a used 4 row NASCAR radiator (I forget the brand, but it was one of the more common ones), but it caused his car to run hotter than the stock 2 row - 26 inch, and he brought the car to me to figure out why.
The engine tune was good, so I contacted the manufacturer of the radiator to try to determine what the problem was. I learned that some radiators use extra rows to LIMIT airflow at high speeds to deflect excess air down and around the car.
Additionally, I have found through experience that non tapered shrouds like the one pictured a few posts above can be very detrimental to cooling at speed as they act as an air dam instead of a funnel.
I can't comment on what is a good brand currently, but a two row 1.25" tube "turbulator" tube style (Turbulator being an industry description of a tube that has rotational veigns inside that spins the water so that the maximum amount of surface area is exposed to the tube surface) should be more than adequate to cool the average big block, or a three row if the tubes and fins aren't to close together so that they don't create an airflow restriction, or make the radiator to thick for a a stock shroud. The more tubes per inch, the fewer rows are usually/actually a benefit to cooling.
One other thing that is important when switching to an aluminum radiator is to try to electrically isolate it as possible. In other words, don't run any grounds that are bolted to the stock radiator, and ideally use a thin rubber insulator between the radiator and the opening, and use nylon mounting bolts. Keep it as isolated as possible as electrical isolation can make an aluminum radiator last for many years, vs. possibly 6 months if you have a decrepit electrical system and stock mounting. --- less than 1/4 volt ground differential will eat, or clog an aluminum radiator in short order.
Lastly, soldered tubes will last longer than epoxied ones over myriads of heat/cool cycles, so unless a manufacturer touts that, they are probably not.
Hope any of this is of help.
